TwinTurbo.NET: Nissan 300ZX forum - Re: Check engine light on in 1996 TT Z..
Subject Re: Check engine light on in 1996 TT Z..
Posted by craigz96tt (SC) on June 27, 2013 at 8:18 AM
  This message has been viewed 196 times.
In Reply To Check engine light on in 1996 TT Z.. posted by zx1988 on June 24, 2013 at 10:59 PM
Message Is purge canister removed or disconnected? Knock harness check connections. You can do a quick fix on it and repair harness but if knock sensor is bad either replace or you can use, I believe a 1000moh resistor between contacts on harness going to ecu to imitate a good voltage. Check the ohms for the resistor, I know Z1 sells a kit but its easy to do yourself
